Author Topic: mk3 gti master cylinder repair  (Read 1681 times)
Offline tweed
« on: 17 June 2009, 22:14 »
hi all. Trying to get the mk3 on the road, it's been sitting for a while and the brakes got spongy, bleed them (twice) and now I'm thinking master cylinder. I've got a seal repair kit. I'm going to attempt to fix it tomo. Anything I should know before I start? any tips or anything?
Oh also it's a 22.2mm bore right?
Offline Diamond Hell
  • Opinions я Us
Re: mk3 gti master cylinder repair
« Reply #1 on: 18 June 2009, 00:26 »
22.2mm sounds about right.
Master cylinders are hardly dear.  I'd vote for replacing the unit, rather than just the seals.
Remove it, refit it, fill the resevoir, give it a few pumps, open the closest bleed nipple, give it a few more pumps and leave it with a pipe on the open nipple, emptying into a receiver and go for a cup of tea.  Gravity and time are your friends, more than pumping and ezi-bleeds, or pressure bleeders etc etc.
Once the fluid's pulled through on one part of the system I would be surprised if you weren't able to bring the others up using the 'normal' two-man bleeding method.
Obviously, make sure the rear compensator valve is opened up when you bleed the rears.
Offline tweed
« Reply #2 on: 21 June 2009, 14:48 »
Don't see the point in getting a new unit when it's only the seals that have gone. How much is a new master cylinder? Not one from a scrapyard. Plus 22.2mm is wrong :( I've got 23mm. so now the car is going to be sitting even longer.
« Reply #3 on: 21 June 2009, 23:02 »
Much better to replace the cylinder you will often find the piston is pitted when you pull them apart.
Offline tweed
« Reply #4 on: 22 June 2009, 09:48 »
it looks fine. How much is a new one? Or where could I find one?
« Reply #5 on: 22 June 2009, 10:57 »
Best bet is to try your local motor factors
Offline tweed
« Reply #6 on: 23 June 2009, 12:44 »
I can't get the seals I want so new one it is. I found a 24mm bore too  :huh: just under £40 not so bad, but everything ads up when you just lost your job.
