Author Topic: My first scan (OBD2)  (Read 3452 times)
Offline Mr_Orange
« on: 17 June 2009, 19:02 »
My first scan with, only got a basic £20 two button job off ebay.  Results below:
16486
(P0102) Mass or Volume Air Flow Circ Low Input
17705
(P1297) Connection turbocharger - throttle valve pressure hose
18010
(P1602) Power Supply (B+) Terminal 30 Low Voltage
Nothing illuminated on dash warnings.  I've cleared the faults for now, will see if they come back.  Car is perhaps a little hesitant on occasion and runs with a slight rpm flutter at tickover.  Nothing on searches for these fault codes, give me the good news please!
Build thread clicky
Offline northeast_gti-t
  • "1.8T AGU"
Re: My first scan (OBD2)
« Reply #1 on: 17 June 2009, 19:10 »
2000 Mkiv GTi 1.8T AGU
  • "1.8T AGU"
« Reply #3 on: 17 June 2009, 19:18 »
Also with regard to the 17705 fault rhys posted this not long ago could be helpful to you as well http://uk-mkivs.net/forums/p/170257/1115840.aspx#1115840  :wink:
Offline Mr_Orange
« Reply #4 on: 17 June 2009, 19:19 »
http://wiki.ross-tech.com/index.php/16486/P0102/000258
http://wiki.ross-tech.com/index.php/17705
http://wiki.ross-tech.com/index.php/18010/P1602/005634
Looks most to likely be:
16486 Dodgy MAF
17705 Boost hose split / loose, or dodgy N249 valve
18010 Battery unplugged
Nothing out of the ordinary!!!
Cheers yo.
Build thread clicky
  • "1.8T AGU"
« Reply #5 on: 17 June 2009, 19:23 »
16486 Dodgy MAF
Cheers yo.
no probs :afro: i had the last two codes you have a little while ago and yes the 18010 fault is when the batterys been disconnected for a period of time the 17705 for me was a knackered hose to the top of the dv also the clip was loose but i have replaced the dv line with silicone pipe now never had the code since  :lipsrsealed:
Offline Mr_Orange
« Reply #6 on: 17 June 2009, 19:35 »
16486 Dodgy MAF
Cheers yo.
There is some light oil/crap evident around the hoses in the dump valve area.  I'll get it cleaned up, take a good look at the hoses and perhaps replace some of the hose clips.
Thanks
Build thread clicky
Offline T_J_G
« Reply #7 on: 17 June 2009, 20:43 »
Did you clear the faults and then re scan mate?
Offline Mr_Orange
« Reply #8 on: 19 June 2009, 11:34 »
Erased faults that day.  Used it for 50/60 miles now with no more appearing in memory
for the time being..........  :lipsrsealed:
Build thread clicky
Offline AlanD
  • MK5 2.0T 16v
« Reply #9 on: 19 June 2009, 12:50 »
As T_J_G says them results could have been generated AAAGGGEEESSS ago. Clear them all and have a good drive for a week or so and then rescan.
HTH.
