Author Topic: golf mk2 digifant no spark  (Read 4594 times)
Offline Winner
« on: 16 June 2009, 21:33 »
Hi can some1 help me plz i got mk2 golf 1.8 digifant engine with no spark. It ran the other day sweat as a nut. but now it has no spark nothing. checked plugs check dizzy checked ht lead an nothing. i hav put new plugs, plug leads an new coil on and had it running on them left it over night. now there is nothin not a sausage.
Plz can any1 help me plz its doin my head in!!  :angry: :angry:
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: golf mk2 digifant no spark
« Reply #1 on: 16 June 2009, 22:18 »
TCI unit on top of ecu bracket?
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 16 June 2009, 22:21 »
It sounds as if you have checked the obvious. When you switch on the ignition, does the fuel pump prime, or run continuously? If it runs continuously, then you may have an ECU problem which will also affect your spark.
Have you tried removing a spark plug, plugging it into a lead then, whilst holding it against the engine block, looking for a spark whilst someone is turning the engine on the key? (Make sure you get a good earth, because you could damage the ECU otherwise, unless of course, the ECU has gone anyway.)
Is the dizzy the type that has an earth lead attached to it? If so, check that the earth lead is still attached. That will prevent it from starting.
Offline Winner
« Reply #3 on: 16 June 2009, 22:29 »
Hi thanks 4 the reply
it is on different fuel pump which runs off a switch i car so i cant tell you that bit. yeh i have earthed the spark plug still nothing, it has a new dizzy on which has a metal piece which is connected to the clamp that holds the dizzy on.
Some1 on here said TCI unit on top of ecu i did think that but wasnt 100% u think it will be that?
« Reply #4 on: 17 June 2009, 08:50 »
Has it got an immobilzer, might be worth checking.
Offline cняis
« Reply #5 on: 17 June 2009, 20:30 »
also known as an 'ignition module' if you have trouble obtaining one  :smiley:
sounds similar to my dreaded project.... except that would start and run with the key turned to ign position 3, but die instantly when the key returned to position 2.... i never did solve that problem....  :sad:
Offline Mew
« Reply #6 on: 17 June 2009, 20:42 »
Give the hall sender connector on the dizzy a wiggle and see if that helps
Offline Mk2Kezza
« Reply #7 on: 17 June 2009, 21:01 »
I second the hall sender idea! Timed up my digifant the other day, then couldn't start her. Wiggled the hall sender and hey presto..
<br />Almost finished.....
Offline DarnPB
« Reply #8 on: 17 June 2009, 22:31 »
It most probably is something you have disturbed when you replaced the ignition parts. Go over everything again, and make sure the plug leads are pushed home well into their sockets. If the HT lead from the coil to the dizzy is not fitted correctly, you will get nothing.
