Author Topic: Is this correct? With pics  (Read 1559 times)
Offline Gloves88
« on: 15 June 2009, 18:15 »
I'm setting up my rear sus and cant remember if this is correct.
Should part 9 be above or below part 21, the circlip?
I cant compare with the sus i have on as they are coilovers. This look fine? -
Also what are these three studs for? Came with my new rocker cover gasket - are they longer for the timing belt cover and earth strap?
Thanks
Re: Is this correct? With pics
« Reply #1 on: 15 June 2009, 19:21 »
Yes you correct on both counts.
Offline Gloves88
« Reply #2 on: 15 June 2009, 19:30 »
So as i have it - washer thing above the circlip?
« Reply #3 on: 15 June 2009, 19:41 »
No sorry I think the washer fits below the circlip.
Offline Gloves88
« Reply #4 on: 15 June 2009, 21:26 »
Cool, cheers.
Anyone able to confirm that for definate?
« Reply #5 on: 16 June 2009, 00:00 »
I am sure that is right as it gives the bumpstop something to act against.
Offline Gloves88
« Reply #6 on: 16 June 2009, 00:12 »
Ok, cheers mate...guess that makes sense. Seems crazy that so much force could be held by such a small matal ring
« Reply #7 on: 16 June 2009, 10:14 »
no the washer goes on top of the circlip, this is what the spring top cup sits on.
Offline daniel-1986
« Reply #8 on: 16 June 2009, 10:28 »
dont do wat a mechanic did with my back suspension and put the washer on top on the top spring plate only to find the shock bouncing inside the car. i only found out the did it the wrong way when i took it apart. the work had been done before i bought the car
Offline Gloves88
« Reply #9 on: 16 June 2009, 11:37 »
Perfect, thanks.
