Author Topic: help please.. electric window motor.... have searched  (Read 825 times)
Offline NEWEY
Hi i need some help.
my drivers side window has packed up on my 16v i have got hold of a brand new motor unit to fit. while searching on the net it also talks about a regulator. where abouts is this and could this be the problem and not the actual motor?
also has anyone any idea how easy these are to fit? a guide would be really helpful. i have done a search but couldnt see anything.
thanks
Offline Dolly
Re: help please.. electric window motor.... have searched
« Reply #1 on: 15 June 2009, 18:16 »
the regulator is what the glass is bolted/fitted to. it contains the cables and pulleys that make the window go up and down. the motor will fit onto the regulator, youll need to remove the door card ect and get to the motor, operate the switch if the motor can be head/felt then there is a possibilty the window reg could have broken, ie a cable snapped.
Offline NEWEY
« Reply #2 on: 15 June 2009, 18:32 »
thats great thanks for your help.
Offline molovin
« Reply #3 on: 15 June 2009, 19:27 »
my cables has snapped so would a regulator from a non elec spec car work fine just replace the cable?
« Reply #4 on: 16 June 2009, 10:11 »
no got to be an electric one
