Author Topic: HELP !! Oil Buzzer sounding??  (Read 2546 times)
Offline bad-vw-boy
  • Man on a golf mission
« on: 15 June 2009, 10:26 »
In the last two days my oil buzzer has been going off on my Mk1 Golf Cabrio i have checked the oil levels and they all seem fine, however this morning on the way in to work after about 2 miles it started two intermitently sound and then after a further mile stopped sounding alltogether. does this mean the oil pump is on the way out, and how can i check.....where can you get a replacement and are they easy to fix if this is the case.
Re: HELP !! Oil Buzzer sounding??
« Reply #1 on: 15 June 2009, 10:28 »
check the wiring to the oil pressure switch on the oil filter housing, its the large white one.
what rpm was it going off at?
Offline bad-vw-boy
« Reply #2 on: 15 June 2009, 22:19 »
i have bike throttle bodies and when u start her u need to use some choke then the revs rise to about 2.5k i then close off the choke
« Reply #3 on: 16 June 2009, 10:10 »
so was the buzzer going off above 2k rpm or below?
Offline bad-vw-boy
« Reply #4 on: 16 June 2009, 10:27 »
the buzzer went off this morning but only after i started driving when i started her she was quiet, but again after about a mile or 2 she went quiet again, inchanged the sender last night, but does not seem to have made any difference, people are saying a clogged pipe on the pick up, but the oil was only changed about 200 miles ago
« Reply #5 on: 16 June 2009, 12:09 »
which sensor did you swap? white one in the filter housing?
Offline bad-vw-boy
« Reply #6 on: 16 June 2009, 12:47 »
i think so the smaller one, got the car booked at my local garage as i dont want her going pop on the way to inters
« Reply #7 on: 16 June 2009, 13:31 »
its the bigger one you need to swap, small one is an oil temp.
« Reply #8 on: 17 June 2009, 08:45 »
Might be worth getting your oil pressure checked as it could be the pick up pipe clogged.
