Author Topic: Is this normal for my wheels ?  (Read 3122 times)
Offline luke0380
« on: 14 June 2009, 23:16 »
I get these , noticably on the back wheels  , should there be that much rust.
Also the wheel nuts, should they be that colour ?
« Last Edit: 14 June 2009, 23:26 by luke0380 »
Offline pazz
Re: Is this normal for my wheels ?
« Reply #1 on: 14 June 2009, 23:50 »
The rust on the hub is quite common on the MK5's. Its an easy fix, just involves getting your hands slightly dirty.
There is a really good "How to" guide on MK5GolfGTi Forum. Just sign up and you can get to them under the "How to Guides/Troubleshooting" section.
As for the wheel nuts, they are just plastic cover's. The nuts are behind the plastic covers. From the picture, it looks like you've had the wheels refurbished????  :undecided: You can buy replacement covers from VW, which should tidy things up a bit.
« Last Edit: 14 June 2009, 23:52 by pazz »
Offline Cass
« Reply #2 on: 15 June 2009, 00:02 »
Yep, typical rust on the disc hubs. Very VW - a cheap paint coating over something that should be much more substantial and long lasting.
Wheels off and silver Hammerite will do the trick.
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline Gene Hunt.
« Reply #3 on: 15 June 2009, 07:53 »
I got a new set of the ''nut'' covers last week £8.00 inc the little removal tool.
Candy White ED35.
Offline Kermit
« Reply #4 on: 15 June 2009, 10:10 »
Good old "rusty" bells - looks awful (mine car is the same).  Some people had them sprayed under warranty and others (like myself) were told it was "normal"!
Are you sure whoever had it before you has not sprayed the wheel nuts to match the rim? Looks like a bad job or it's starting to flake off?
2007 GTI, Steel Grey, DSG with Paddle, Leather, 18" Monza, Xenons, Lux and Winter Pack, iPod, Tints
Offline ifti
« Reply #5 on: 15 June 2009, 11:10 »
The rust is caused by the brake dust that falls onto the hubs. This dust then rusts when it gets wet, and sticks onto the hub.
I have it on mine as well, but havent got round to doing anything about it yet! lol
What most people do is remove the wheel, then paint the hub with Hammerite Smooth Silver Metal Paint. This protects it from more rust, and you get a nice smooth silver finish.
neo66
« Reply #6 on: 15 June 2009, 13:11 »
Just doing mine this very moment!
I brought a pot of Hammerrite smooth in white because I WAS going to use a brush to paint it as overspray can happen so easy with a can, but then for some reason the Hammerrite smooth hasn't taken to it for some reason (maybe the brush as the paint was quite thick and sh!t looking, I'm not really sure).
Anyway So now I've taken the actual disc off instead and brushed off all the white crap to start again. Luckily I found a spray can in silver/chrome (rather keep it original now after seeing the white!). Now it's drying much better as theres no stroke marks and best off all it's getting sprayed no where near the car.
Pics to follow possibly.
Offline luke0380
« Reply #7 on: 15 June 2009, 13:15 »
i can only imagine they were done before i brought the car , do they have a part number for the covers?
Offline Gene Hunt.
« Reply #8 on: 15 June 2009, 13:29 »
......got my ''new'' nut covers off ebay just search on there mate.
Candy White ED35.
« Reply #9 on: 15 June 2009, 13:56 »
Clean the center part of the disc with a wire brush then use silver hammerite.
