Author Topic: Annoying buzzing above 2500RPM  (Read 1417 times)
Offline mugsy
« on: 18 August 2004, 19:12 »
i tried finding everything out on the net but cant figure it out. when i go above 2500rpm the oil light flashes and and it buzz's which is very annoying. Is there a way to sort this out?
what is it thats causing this?
Any help would be much appreciated thankyou ^-^
Blue MK2
Re: Annoying buzzing above 2500RPM
« Reply #1 on: 19 August 2004, 05:02 »
im not sure of this but i think low oil pressure or low engine oil?
My polo did that but here was no faults with the engine but with the sensor. Connected the sensor wire to 'earth' and that shut it up :D
Offline GavG60
  • keep my credit cards away from me please :-(
« Reply #2 on: 19 August 2004, 09:07 »
I had this problem on my 16v. I changed both the oil sensors on top of the oil cooler (pattern parts) for original VAG ones and it went away.
worth a try as they are cheep!
Gav
Offline Gambit
« Reply #3 on: 19 August 2004, 14:42 »
if what gav says doesnt cure it then there is a partial blockage in the oil pickup in the sump
enough oil can just about get past, but once under load the engine is being starved of oil hence the light/buzzer warning
