Author Topic: 4 different types of pads for my car??  (Read 2280 times)
Offline DAVEMARX
Re: 4 different types of pads for my car??
« Reply #10 on: 14 June 2009, 19:35 »
tryed halfords?
they got a list in there of what you need.
my rears cost £17 and i done them myself its a peice of cake.
all you need is an alan key, hammer, and long nose pliers.
release the 2 nuts with alan key
beat of the caliper with the hammer
then turn and push the break piston clockwise with the pliers....job done in about 30-40 mins
Offline avengedslayer
« Reply #11 on: 14 June 2009, 19:37 »
okay found this pic thats quite helpfull, just use a g clamp to open it up?, is that just so I can get the new pads in then? also will i need to get some brake fluid? :smiley:
« Reply #12 on: 14 June 2009, 19:38 »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #13 on: 14 June 2009, 19:47 »
What ever you do, do not use that technique on the rear calipers as they have to be wound back (usually with a specific brake winding tool as they can be very tight) Forcing them straight back will ruin them indefinitely.
« Reply #14 on: 14 June 2009, 19:50 »
so i am assuming front brakes are fine to do it with this technique :smiley:
Offline DAVEMARX
« Reply #15 on: 14 June 2009, 19:51 »
im not shore but i think the fronts are just push pistons where as the back are screw in's..
ive only done the rears on my mk3 8v because the caliper came of due to the former keepers dodgy diy skill.  But on my old95 seat toledo id done the fronts and they were just push'ys.
you wont know til you take the pads out or someone has defo answer if there screw ins the piston will have grooves in it for a special vw tool...or long nose pliers...
hope this elps but do it yourself co its cheap and easy.. be careful tho when i done the rears i didnt chuck the front wheels and it ended up on its axles...
Had to get the good old widow maker out to get the fat slag back on all 4 wheels
Offline DAVEMARX
« Reply #16 on: 14 June 2009, 19:55 »
now that ive thought about it yeah they are differant front and rear
front are push'ys...use g clamp
rear are screwed....use long nose pliers
« Reply #17 on: 14 June 2009, 19:55 »
I use one of these on my rears, they can be used for the fronts but a big lever ( or clamp as shown) will suffice on these.
http://cgi.ebay.co.uk/Draper-ABS-Hand-Brake-Caliper-Piston-Wind-Back-Tool_W0QQitemZ130311393532QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item1e572a10fc&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1689|240%3A1318|301%3A0|293%3A1|294%3A50
Some info on brakes. http://www.alcester-racing-sevens.com/rear_brake_pads.htm
Offline Mikester
  • Civic Type R
« Reply #18 on: 14 June 2009, 20:20 »
GSF knew exactly what i needed just from the reg. Fitted fine.
« Reply #19 on: 14 June 2009, 21:44 »
okay thanks for all the comments, im gonna grow some balls and fit them myself, im gonna get new discs too and already got some brake caliper paint (yellow) so should look much nicer and perform much better when done  :smiley:
