Author Topic: Have any of you succesfully got a replacement key to work via Ebay purchase  (Read 3252 times)
Offline celica
Have any of you succesfully got a replacement key to work via Ebay purchase:
- to get them cut by a local car key cutter
- and then reprogrammed?
I've head mixed reviews about this. I know mk4 owners have done this relatively easy, but mk5 is slightly different in the reprogramming from what I have read.
Considering this option if some of you can confirm it works this way, as it beats the dealer prices!
Offline sixpot
I have successfully bought a key and blank blade from ebay, had it cut at a specialist laser key cutter www.nwkeys.co.uk
but I still had to take it to the main dealer to be coded in which cost me approx £50, so it's not a lot cheaper really. This was not for a mk5 Golf, but I imagine it would involve the same process.
I purchased a new key from the dealer for my mk5 which cost me approx £150, but there was no running round to do!
Offline bobotheclown
there was a thread on how to recode blank keys. I think it had something to do with open the car with the key that works/second key. Put the blank in the ignition. Turn key so that electrics come on but not start the engine. Get out and lock the car. Or something like that. I tried a search but didn't come up with anything so it might have been on another website. Sorry to tantalise you with a possible solution but I did give a google search a go and everything.
Offline celica
thanks
i heard something like that but for a mk4 and not mk5 confirmed
Offline sambo
That only codes the remote for central locking IIRC. To start the car, it needs to be coded by VW/vagcom etc to sync the keyfob with the immobiliser.
HTH Sam   :smiley:
Sam
AXX power!  ..   Tinkering has started.... :smiley:
TeddyKGB
I'm pretty sure it does involve dealer or vagcom if you have one/know someone with it
Offline celica
thanks
i've done a bit of research and got a little confused.
need to programme transponder which is the chip to start the car and the key fob to lock and unlock
Offline jaydubveedub
Best thing to do is get your dealer to supply and fit imo. Sounds like the DIY route doesn't save you much money, and involves lots of running around.
2003 Passat 1.9 Sport TDI Wagon | Inky Blue | Lots of Wax
Offline MrShabz
I tried an ebay key when I had my Golf, got it cut from locksmith but VW couldnt program it..
Nighthawk Black FN2 Civic Type R...................VTEC yo!
Offline sambo
Best person to ask is old no7 he's an electronic wizz! Usually lurk's around the mk4 section!!
Sam
Sam
