Author Topic: breather on a 2liter  (Read 1009 times)
Offline bazzza
« on: 13 June 2009, 22:14 »
er i'v just got a 2liter mk3 bottom end an it has a oil breather on it next to the oil cooler  can i block it up ..??.is goin on my ev kjet enigne 8v !!
Offline Diamond Hell
  • Opinions я Us
Re: breather on a 2liter
« Reply #1 on: 13 June 2009, 22:55 »
TSR do them, but make sure you're allowing the crank pressure out somewhere, or you'll start blowing seals, matron.
Offline deanpompey
« Reply #2 on: 14 June 2009, 15:47 »
another way to do it is to extend the crank breather hose up to where the rocker breather is, and join them onto the GTI flying saucer with a t piece, then attach as normal to the inlet mani... much better if you ask me  :nerd:
« Reply #3 on: 14 June 2009, 19:10 »
As above is the better way.
VeeDubGTI16v
« Reply #4 on: 14 June 2009, 19:25 »
or send them both to a catch tank/lucozade bottle
Offline bazzza
« Reply #5 on: 14 June 2009, 21:00 »
thanks... all so is the warm up valve just bolted to the blocks ie there's not a hole behind it just a case of movin it, an as 4 the fly wheel do i use my mk2 one with a mk3 clutch or a mk2 clutch? plannin to put it in next week ???
