Author Topic: fuel gauge  (Read 1391 times)
Offline reed5410
fuel gauge
« on: 12 June 2009, 23:43 »
hi, ive got a problem with my fuel gauge reading fullwhen the ignition is on and there is hardly any in it, my question is how hard is it to remove the sender and how do you go about it, many thanks 4 your help
Offline Grim_Reaper
  • warningz...i haz powaz
Re: fuel gauge
« Reply #1 on: 12 June 2009, 23:47 »
AFAIK there are 2 senders, one in the dash clocks and one in the tank or something but i cant remember of hand...also from what i remember, the dash one can go and is usually the one that goes
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: fuel gauge
« Reply #2 on: 12 June 2009, 23:49 »
from what i understand it can be a little bit tricky as the pump / sender unit can be a pig to remove without the proper tool. it can be done with water pump pliers but apparently the locating tabs cab break off quite easily then forcing you to have to drop the tank to remove it for replacement.
Offline Grim_Reaper
Re: fuel gauge
« Reply #3 on: 12 June 2009, 23:52 »
if you know anyone else with a mk3 and if they are nice enough then i would just swap the clock cluster just to rule out a faulty gauge
Offline christomk3gti
Re: fuel gauge
« Reply #4 on: 13 June 2009, 00:06 »
I have problems with my gauge now and again.... it suddenly goes quite low, but then look again later and its back to where it was.. I'm like ehhh? seems to start doing this around the Middle mark of the gauge....
Black 8v GTI............. Whats a Waffle Valve?
Re: fuel gauge
« Reply #5 on: 13 June 2009, 00:07 »
Mine was the same, was told by VW it is normal.
Re: fuel gauge
« Reply #6 on: 13 June 2009, 00:11 »
Yep, mine does that occasionally. it's a f*ucker for knowing if you've allowed yourself enough petrol for along trip sometimes.
Re: fuel gauge
« Reply #7 on: 13 June 2009, 01:01 »
Ahh well glad its ok, just one more thing, Do the mk3 gti 8v's have a petrol light on them? I've never let it go too far in the red to check for a light, but i cant seem to see one...
again thanks.
Re: fuel gauge
« Reply #8 on: 13 June 2009, 01:12 »
Not on mine no.
Re: fuel gauge
« Reply #9 on: 13 June 2009, 01:16 »
I'll just keep doin what i do then and i should be ok :)
