Author Topic: A/C service  (Read 1153 times)
Offline D Squared
A/C service
« on: 12 June 2009, 21:33 »
Just had my A/C serviced.., so recharge, anti-bacterial spray into vents, pollen filter etc etc... bloody freezing now.. top job well worth doing..
MK3-MK5- Now MK7 GTi
Offline Adam
Re: A/C service
« Reply #1 on: 12 June 2009, 21:40 »
How much did you pay? Was it smelling or not as warm as should be?
May look into this
Down Hill From Here.
Offline D Squared
Re: A/C service
« Reply #2 on: 12 June 2009, 22:52 »
May look into this
it wasn't smelling, but not as cool as it should be... it only had 200g of gas in it, and to fill it up is 850g...
i got a deal as it was my mate that does it..., but he normally charges £55 + vat for labour, gas and anti-bacteria spray, if a pollen filter is req'd that is extra.. if the car then leaks all the gas out - due to a hardware problem, i.e leaking rad or something, he would only charge for the gas just lost @ £30 + vat.
Hope that helps..
Offline akaruben
Re: A/C service
« Reply #3 on: 13 June 2009, 12:57 »
Mine wasnt very cold the day I bought it and really wanted air-con so has a service on it. Fantastic. Freezing cold and odourless. Well chuffed with that.
Offline Shady Pioneer
  • graphic designer.
Re: A/C service
« Reply #4 on: 13 June 2009, 18:56 »
When I get my car sorted I'll be getting the A/C serviced, it's cold but not as much as it should be, would imagine it's just running out of zee gas it needs :)
Re: A/C service
« Reply #5 on: 13 June 2009, 20:18 »
A specialist should check for leaks first with a special dye then regas as required, otherwise your new gas goes really quickly.
Offline D Squared
Re: A/C service
« Reply #6 on: 14 June 2009, 21:52 »
all new a/c fitted cars have the dye built into the gas.., not sure if you can just put the dye into a system that doesn't already have it.... be good if you could then like you say could check for leaks with the ultra violet light before you pay to charge the system..
Re: A/C service
« Reply #7 on: 14 June 2009, 23:06 »
Yes you can, I work with air con everyday, the correct way is to drain and vac the system down, then check for leaks whilst doing a full pressure test, if all ok, regas and top up oil as required.
