Author Topic: rattle  (Read 1648 times)
Offline coggers79
rattle
« on: 12 June 2009, 18:13 »
i got a rattling noise from the front passenger side any idaes what could be sounds like a suspension or steering component
Christo77
Re: rattle
« Reply #1 on: 12 June 2009, 19:11 »
Definitely outside of the car? and is it a rattle..or a knocking noise?  if it's suspension/steering related then you might feel the problem as well as hear it..It could be the old heatshield problem but difficult to say without more info..
Offline boneybradley
  • Back in a Mk3...
Re: rattle
« Reply #2 on: 12 June 2009, 19:39 »
I have a feeling it is the heatshield issue! you need to get under the car and see if any have movement! and bin or refix if they have
Offline Grim_Reaper
  • warningz...i haz powaz
Re: rattle
« Reply #3 on: 12 June 2009, 22:33 »
when do you get the rattle??? taking a corner?? going over a bump?? going over a bumpy road or just randomly coming?
also, does your car pull to any side or is it lighter to turn to any side?
Offline coggers79
Re: rattle
« Reply #4 on: 13 June 2009, 08:42 »
car pulls to left but this is down to corroded alloy losing pressure it rattles over any road surface it sounds like my alfa did that was a drop link but its just had mot with no advisaries up on ramp nothing is apparent definitley metal on metal noise
Re: rattle
« Reply #5 on: 13 June 2009, 09:25 »
Well worth checking your top mounts.
Offline DAVEMARX
Re: rattle
« Reply #6 on: 13 June 2009, 16:38 »
I got the same problem...
Started a few days ago i thought the exhaust was banging against the body work but its not..
There are no loose heat sheilds and noting in the boot banging around.
Its driving me nuts...
It sounds like somethings loose and hitting metal. I thought someone put marbles or something in the back box...
dave
Re: rattle
« Reply #7 on: 13 June 2009, 17:09 »
dave
Check your rear top mounts, they can let go and start banging etc.
Offline coggers79
Re: rattle
« Reply #8 on: 13 June 2009, 17:44 »
how do i check top mounts any pics
Offline karl29
Re: rattle
« Reply #9 on: 13 June 2009, 18:36 »
i had a similar problem but mine was the brake hose had come loose where its attached to the front strut and its held on by a bolt so that may be worth looking at i tightened mine up and it stopped
