Author Topic: coilovers rubbing on tyres  (Read 1660 times)
Offline carlgti
« on: 11 June 2009, 23:42 »
this may have been asked before, i apologise if it has but ive just fitted fk coilovers to my mk3 gti and the spring/bottom adjuster rubs on the tyre sidewall when i hit a bump. I currently have standard gti wheels and the car is lowered quite a bit, my question is will raising the car a bit help solve the problem or do i need different wheels or spacers
cheers
carl
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
Re: coilovers rubbing on tyres
« Reply #1 on: 11 June 2009, 23:46 »
you'll probably need spacers my friend
« Reply #2 on: 11 June 2009, 23:48 »
Are you running 205/50/15's if so then run a 3mm spacer or switch to 195/50's
Edit: just reread it and it cannot be catching the spring plate as that moves with the wheel so it must be rubbing the arch.
« Last Edit: 11 June 2009, 23:52 by Wayne »
Offline carlgti
« Reply #3 on: 12 June 2009, 00:21 »
hmm ill check again tomorrow i did notice a mark round the inside of the tyre which looked like it had been rubbing, but i will also double check to make sure its not hitting the arch.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 12 June 2009, 07:08 »
maybe the the wheel is buckled or badly balanced?
Offline Len
« Reply #5 on: 12 June 2009, 21:01 »
Something wrong mate!
I have run 215/40's and they didnt rub the strut!
So you got a problem somewhere!
www.sas.org.uk
www.the-ace.org.uk
Offline carlgti
« Reply #6 on: 13 June 2009, 19:53 »
hmm ill get out tomorrow and have a good look around it me thinks
Offline Dan34
  • VTEC Powerzzzz
« Reply #7 on: 13 June 2009, 19:57 »
if its on the front maybe you should get your camber checked? :smiley:
Dan
Offline rob026
  • Mk3 16v GTI
« Reply #8 on: 13 June 2009, 23:08 »
This happened to me, and it was because of the camber
