Author Topic: will mk2 into a mk1  (Read 2176 times)
Offline andc1
will mk2 into a mk1
« on: 10 June 2009, 21:30 »
hi all, will any mk2 bits fit my mk1? i mean like interior, trim, i can get a mk2 3 door valver quite cheap and i have a mk1 valver so i no the engine will come in handy!
Re: will mk2 into a mk1
« Reply #1 on: 11 June 2009, 10:37 »
pretty much only the engine and wheels are any good! front seats go in but the forward/back sliders are on the wrong side so to move the seats you have to reach under and release the pin.
Offline andc1
« Reply #2 on: 11 June 2009, 14:39 »
what about rear seat? seat bellts and trim, i no i might have to cut the trim down abit but will it fit?
« Reply #3 on: 11 June 2009, 14:55 »
seat will need mods, belts might fit but mk2 belt clips are a different style to mk1 if its an early one so you';ll need to make sure you swap everything over.
Offline andc1
« Reply #4 on: 12 June 2009, 20:41 »
when u say the rear seats need mods? just the fittings on it? what about all the plastic trim, bit of trimmng and it wll fit wont it????!!!!! :laugh: :laugh: :laugh: :wink: :wink: :wink:
« Reply #5 on: 15 June 2009, 08:39 »
it'll take a lot more than 'a bit of trimming' the frame work of the car is a totally different shape. the benches can be made to fit apparently, iirc the mk2 bench is actually a little narrower than a MK1?  if you have the bits, try it ;)
Offline Tramp
« Reply #6 on: 17 June 2009, 19:06 »
I tried to put some MK2 seats into a MK1 and It just don't work. The rails are set up different and to modify them is easier said than done.
The engine can be fitted but the Manifold faces a different way but that can be compensated for.
