Author Topic: has a dilemma  (Read 1650 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
has a dilemma
« on: 10 June 2009, 12:17 »
well i want to fit coilovers
but... its not that easy, my front drivers side jacking point does not like being jacked up at all
so with jacking it up i cant really do it.
but i need to :undecided:
so i rang up a garage and for fitting they wanted £200+vat
(this is a vw specialist we're talking about)
so is there any way round this?
Offline Adam
Re: has a dilemma
« Reply #1 on: 10 June 2009, 12:24 »
Use a bit of wood to distribute the weight over an area when jacking it up.
Use the widow maker if you dare......
Down Hill From Here.
Re: has a dilemma
« Reply #2 on: 10 June 2009, 12:25 »
Yes look under the car and where the wishbone mounts jack it there (not on the wishbone), I always do it that way.
Offline tobybrennan
Re: has a dilemma
« Reply #3 on: 10 June 2009, 12:29 »
i dont use a widow maker
many bad experiences, so got myself a decent jack:)
so not on the wishbone, on the wishbone mounts?
is this a straight swap job?
Re: has a dilemma
« Reply #4 on: 10 June 2009, 12:31 »
Yes on the wishbone, reference fitting them, my fitting guide is in this thread http://www.golfgtiforum.co.uk/index.php?topic=68845.0
Offline tobybrennan
Re: has a dilemma
« Reply #5 on: 10 June 2009, 12:35 »
okay thanks:)
Offline VR6-Joe
Re: has a dilemma
« Reply #6 on: 10 June 2009, 12:51 »
Where's Kettering?
I fit coilovers for my mates all the time, only charge them 30 quid
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline tobybrennan
Re: has a dilemma
« Reply #7 on: 10 June 2009, 16:17 »
by northamptonshire if you know where that is matey
Offline Grim_Reaper
  • warningz...i haz powaz
Re: has a dilemma
« Reply #8 on: 10 June 2009, 17:11 »
you could always use a jack and a piece of wood and jack it from the front cross member...ive do it all the time on my mk3 and its more rotten than a pear...
edit - realistically (if you know what your doing) you just need the front wheels of the ground, also once you jack it just shove a set of axel stands on the chassis rail somewhere and remove the jack, even more safe then
Offline tobybrennan
Re: has a dilemma
« Reply #9 on: 10 June 2009, 17:13 »
yeah i'll give that a go:)
put axle stands on or something to
