Author Topic: Quick 8v digi temp sender question  (Read 842 times)
Offline jezza16v
« on: 09 June 2009, 19:54 »
Hi, I know we hear a lot about the 'blue' temp sender but there are actually two that look the same on the front water flange, just the connectors that go on to them are blue or black on mine. Are these two temp senders supposed to be the same or are they different part numbers? Thanks
Re: Quick 8v digi temp sender question
« Reply #1 on: 10 June 2009, 08:29 »
no not the same, one should be blue (ecu) the other black (dash temp gauge)
Offline jezza16v
« Reply #2 on: 10 June 2009, 10:20 »
Hmm! Cleaned them up, both black on mine, was suspicious because the latest arrival has blue at the back and black at the front. More expense, just flushed and changed the coolant as well......bu**er!   :rolleyes:
« Reply #3 on: 10 June 2009, 11:30 »
new blue sender is 13+vat from vw, and if you do it with engine stone cold you wont loose more than a few drops o coolant ;)
Offline jezza16v
« Reply #4 on: 10 June 2009, 14:33 »
Ever the optimist RJ, thanks for your advice, new blue sender ordered for installation at the weekend.
