Author Topic: Engine idle and running issues!  (Read 2792 times)
Offline funkyfive
« on: 09 June 2009, 19:15 »
My 8v idles rough and hunts when i start her up and when she is at temperature, this seems to be getting worse and to add to this, i am getting issues when accelerating.
Checks so far.
Changed spark plugs
Changed dizzy cap
Changed rotar arm
Used redex
Changed lamba sensor
Changed fuel filter
Changed frount engine mount
Changed panel filter
No errors on vag.com
Offline christomk3gti
Re: Engine idle and running issues!
« Reply #1 on: 09 June 2009, 19:19 »
clean your throttle body out with some carb cleaner and a tooth brush or something... and check your vacuum hoses on the throttle body, I'm in the process of replacing some hoses and gunna clean the throttle body, so i hope my issues are sorted aswell. (mine arnt tooooooooo bad tho) just want to keep on top of it really.
Black 8v GTI............. Whats a Waffle Valve?
Offline funkyfive
« Reply #2 on: 09 June 2009, 19:33 »
Let us know how it goes?
What model gti have you got?
Offline Edwh0re
« Reply #3 on: 09 June 2009, 19:46 »
Sounds similar to the issues that I had, in the end I had to replace the AFM.  Try disconnecting it to see if it makes a difference....
Offline funkyfive
« Reply #4 on: 09 June 2009, 20:14 »
Not to sound daft but what is a AFM?
Offline mumbles
« Reply #5 on: 09 June 2009, 20:30 »
I think he means Air Flow Meter... if not then check that too!
mine had a similar problem, it turned out to be the water temp sensor.
goodluck.
Wouldn't be fun if it was easy, but does it have to be this much fun?
Audi A4 Sport
Offline funkyfive
« Reply #6 on: 09 June 2009, 21:32 »
Can you clean the MAF, if so what do you use and are there any gaskets?
« Reply #7 on: 09 June 2009, 21:33 »
AFM u mean hehe  :grin:
Offline funkyfive
« Reply #8 on: 09 June 2009, 21:36 »
Yeah lol, have you cleaned yours?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #9 on: 09 June 2009, 21:42 »
Mass Flow meter, Air Flow Meter, Mass Air Flow, Air Consumption Meter...etc etc etc. All correct names for the same thing.
