Author Topic: G60 Fuel pump  (Read 4998 times)
Offline 993turbo
  • Too many cars, too little time......
G60 Fuel pump
« on: 08 June 2009, 22:45 »
Where is the fuel pump on the G60? Its an intank pump I take it.
Only one pump?
:embarassed:
93 Golf VR6 (burgundry) - 93 Golf VR6 (silver) - Ferrari 360 Modena - Porsche 928S2 Strosek - Porsche 928GT
Offline danny_p
Re: G60 Fuel pump
« Reply #1 on: 09 June 2009, 09:47 »
in tank lift pump under car pressure pump like all other injection mk2's
all the VW's have gone bar 1.
Offline 993turbo
Re: G60 Fuel pump
« Reply #2 on: 09 June 2009, 09:48 »
I have taken out the pump in the tank. Its a rather large beige plastic lump with the level sensor attached.
Can the pump (only) be changed, or do I need to change the whole plastic affair?
Offline 993turbo
Re: G60 Fuel pump
« Reply #3 on: 09 June 2009, 09:49 »
If so, where is the pressure pump located? It is not one close to the fuel filter as one should expect....?
Offline 993turbo
Re: G60 Fuel pump
« Reply #4 on: 09 June 2009, 10:12 »
I've had a look under the car, and I can not find another pump. I simply follow the fuel lines (both feed and return) from the tank, to the fuel filter (which is a stand alone unit located in front of the right side rear wheel) and forward to the engine. No other pump in sight.  :embarassed:
Offline 993turbo
Re: G60 Fuel pump
« Reply #5 on: 09 June 2009, 10:30 »
Heres the pics of the Fuel pump unit:
Please note the ''broken membranes'' on two of the pictures.......
Re: G60 Fuel pump
« Reply #6 on: 09 June 2009, 10:50 »
The intank pump is also called a lift pump, the main pump is under the car.
Re: G60 Fuel pump
« Reply #7 on: 09 June 2009, 11:00 »
there is no under car pump on a G60, just the intank pump.
Offline 993turbo
Re: G60 Fuel pump
« Reply #8 on: 09 June 2009, 11:01 »
Where is it???
This is a pict of the area of the Fuel filter........
Any suggestions?
Re: G60 Fuel pump
« Reply #9 on: 09 June 2009, 11:02 »
I stand corrected.
