Author Topic: G60 Losing power  (Read 16680 times)
Offline 993turbo
  • Too many cars, too little time......
Re: G60 Losing power
« Reply #90 on: 07 October 2009, 12:20 »
Just a little update!
After adjusting the car 100% it has been running like a GEM. No Digilag, it pulls strong etc...etc.. Feels really good. My GF is really happy!
 :smiley:
93 Golf VR6 (burgundry) - 93 Golf VR6 (silver) - Ferrari 360 Modena - Porsche 928S2 Strosek - Porsche 928GT
Offline 993turbo
« Reply #91 on: 07 October 2009, 12:25 »
Just ordered a new bolt, pulley and woodruff key. Hope they arrive before the weekend. :smiley:
Darn PB, did u manage to have a look at it? Maybe you have the same type of crank / pulley like mine. Which means no woodruff key......
Offline 993turbo
« Reply #92 on: 07 October 2009, 13:20 »
here is some info on the pulley etc..
http://www.dubforce.net/forums/index.php?showtopic=18283
Offline Organisys
  • Old and Slow...
« Reply #93 on: 08 October 2009, 12:22 »
I <3 Dubforce. Good info there.
Offline Mrpug
« Reply #94 on: 09 October 2009, 02:56 »
Hows the compression?? Also check to see if the timing belt has jumped a tooth or 2 If it's blowing fuel smoke out the pipes, check the mixtures.... this sounds rich to me.. When the gas peadal gets pushed down does a lot of smoke (dark smoke) Also I'd look at the ecu, if those go bad they can cause such problems along with o2 sensor, are any wires burned or grounding out. Or maybe a patato got stuck far into the pipes..... or maybe a dead animal or snakes....?? hope some of this helps good luck. keep us posted.. cheers
Offline Mew
« Reply #95 on: 09 October 2009, 14:39 »
Might be worth reading the latest post or 2 :wink:
