Author Topic: G60 Losing power  (Read 16679 times)
Offline 993turbo
  • Too many cars, too little time......
Re: G60 Losing power
« Reply #70 on: 27 June 2009, 07:19 »
White one last pic its the best one IMO!  :cool:
Far enough mate I know what its like to drive a tank and then get into a G60!
Cool, I will try to get hold of the ECU then...
93 Golf VR6 (burgundry) - 93 Golf VR6 (silver) - Ferrari 360 Modena - Porsche 928S2 Strosek - Porsche 928GT
Offline 993turbo
« Reply #71 on: 27 June 2009, 07:20 »
Ohhh, and tell me:
Distributor. Which distributors are compatible with my car???? GTI 8v? GTI 16v? Only G60's?? or.........
Any info on this, anyone???
Offline 993turbo
« Reply #72 on: 27 June 2009, 21:20 »
I have bought the DP ECU now, and will install it when it arrives.......................
Im going to get a distributor as well... and a lamda sonde, and a ''lamda relay''........
Shot-gun, diagnostics!!!! Big time!
Offline clipperjay
« Reply #73 on: 27 June 2009, 23:18 »
Ohhh, and tell me:
Any 8V distributor will work, but stick to the part numbers you know on the dizzy body the number on mine is the following: 16V will not its side mounted and wont fit!
037 905 205G this might be superseeded at VAG another part number 0237 520 026
Offline 993turbo
« Reply #74 on: 28 June 2009, 08:06 »
Thanks again clipperjay. I will get a dizzy from a G60, just to be sure....
Offline 993turbo
« Reply #75 on: 01 July 2009, 13:25 »
Just a quick question: Does my car have a ignition control module in addition to the ECU. If so, where is it, and how do I test it... ? Is this a common source of fault?
Offline 993turbo
« Reply #77 on: 01 July 2009, 14:52 »
NO you don't!
Thanks :-) One less thing to think about :-)
Offline 993turbo
« Reply #78 on: 19 July 2009, 10:56 »
Can anyone point me in the right direction to the location of the ground points to be checked...?
« Reply #79 on: 20 July 2009, 09:08 »
has to be a digifant 8v one tho, basically if it doesnt have a vacuum unit on the side then it will probably work. excsept MK3 2.0 ones, as they're too big to fit. 1.8 MK3 one might work too, I think the block is the same...
