Author Topic: G60 Losing power  (Read 16705 times)
Offline DarnPB
  • Formerly Darnpistonbroke
Re: G60 Losing power
« Reply #20 on: 09 June 2009, 20:22 »
DarnPB, now your over here, why dont you get to these guys http://www.g-werks.com/Contact/1/Default.aspx one day, as they'll give you the best info on where the problems may be. Have a health check service, rather than a full service or something.  It might point 993turbo in the right direction too, once you find where the problems are.
That is my plan one day when I get the time. Work is very hectic at the moment and I have to juggle my time between here and Spain, as my family are still out there.
Offline 993turbo
  • Too many cars, too little time......
« Reply #21 on: 18 June 2009, 14:31 »
Ok, got the new Fuel Pump. Installed the pump, but no change to the problem :-(
 :cry:
So, the following is new, or has been checked:
-Fuel Pump (New)
-Fuel Filter (New)
-Air Filter (New)
-Vacuum Hoses Checked and changed
-Boost Hoses Checked ok
The car idles perfectly, but does not rev up properly and has no power.
I did an Compression test just to get an idea of the combustion chamber status. All 4 cylinders perfectly lined up around the 150psi mark. In my book this is good. I did not bother to perform a leakdown test as the numbers were so even.
93 Golf VR6 (burgundry) - 93 Golf VR6 (silver) - Ferrari 360 Modena - Porsche 928S2 Strosek - Porsche 928GT
Offline 993turbo
« Reply #22 on: 18 June 2009, 14:34 »
I will check the timing belt, if it has ''jumped'' a tooth, however unlikely due to the smooth idle.
Does anyone have a good description / pics of the marks on the crank - cam?
Further, I will do a check on the iginition timing.... This seems like a hard job with the intercooler etc in place.....
Any other hints and tips...?
VeeDubGTI16v
« Reply #23 on: 18 June 2009, 14:40 »
« Last Edit: 18 June 2009, 14:49 by veedubgti16v »
Offline 993turbo
« Reply #24 on: 18 June 2009, 19:07 »
Cheers for the timing info... Great Stuff!
Any other ideas on the loosing power issue?
Offline bomp
« Reply #25 on: 18 June 2009, 20:40 »
Do you get the same readings as this guy? http://www.youtube.com/watch?v=6bswDjsmP_w
.6 bar (atleast) on the G-Lader.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline DarnPB
« Reply #26 on: 19 June 2009, 07:58 »
Have you disconnected the lambda yet and gone for a drive? The lambda connector is on the passenger side down by the exhaust manifold. Just pull that off and tuck the loom away, then go for a spin.
My next job is to clean the injectors in an ultrasound bath. I've tried everything else. :sad:
Offline 993turbo
« Reply #27 on: 19 June 2009, 16:53 »
http://the-corrado.net/forum/viewtopic.php?f=1&t=67859
have a read through that for the belt timing, and guides for ig. timing below  :afro:
http://vwtech.no-ip.info/downloads/pgigntiming.pdf
http://vwtech.no-ip.info/downloads/pgidleco.pdf
I have checked the Timing Belt acc to the info in the links above. All settings line up: Cam wheel - Crank - Dizzy.........
Offline 993turbo
« Reply #28 on: 19 June 2009, 16:54 »
I get 0.6 bar at around 2500rpm, and this rises to about 0.8 at 3500rpm... So this seems fine!
Offline 993turbo
« Reply #29 on: 19 June 2009, 16:55 »
Yeah, tried to disconnect and drive the ECU into ''safe'' mode but no change.....  :cry: :cry:
