Author Topic: Which brake vacuum pipe?  (Read 918 times)
Offline maxp
  • J reg 8v digi gti
« on: 08 June 2009, 19:34 »
Need to replace this pipe, but interestingly the etka pic shows the pipe goes all the way from the valve next to the manifold straight into the master cylinder.
Whereas mine goes from the manifold, to the valve, but then theres another valve or something halfway between (you can see it at the back).
Confused!??
Re: Which brake vacuum pipe?
« Reply #1 on: 09 June 2009, 10:53 »
ignore the pic its for LHD models, just make sure you pick 'RHD' from the list of available parts for your engine code ;)
