Author Topic: Idle Problems  (Read 1629 times)
Offline Jayjay
Idle Problems
« on: 17 August 2004, 10:50 »
Hello Everyone,
just plugged a VAG-COM cable due to an idle problem, gave me the following code:
00515 - Camshaft Position (Hall) Sensor (G40)
        16-00 - Signal Outside Specifications
has anyone come across this before? can change this myself easily? or is it a dealer job?
kniterider
Re: Idle Problems
« Reply #1 on: 17 August 2004, 10:59 »
was a piece of cake on my mk4 20v gti, just 2 bolts, done in about 5 mins, i never had any idiling probs caused by this just lumpy power delivery and a massive 50mpg!! once changed power back to normal (ish) and petrol consumption back to normal 38 mpg ish.
if the error cant be reset then it is likely that the sensor is faulty, i had a spare one for mine.
good luck
Gaz 8)
Offline Jayjay
Re: Idle Problems
« Reply #2 on: 17 August 2004, 16:35 »
Ive reset the dam thing plenty of times hoping it would just go away,
apart from the idle i do have problem with a slight stumble while driving, maybe it is this part,
problem is I dont even know where to start looking!!! any ideas would be greatly appreciated.
By the way I have a Mk3 GTI 8V
vwsystems
Re: Idle Problems
« Reply #3 on: 05 September 2004, 02:03 »
hall sensor may be located on the cylinder head it measures the camshaft position!
on the old gtis it was built into the distributor!
Offline Jayjay
Re: Idle Problems
« Reply #4 on: 07 September 2004, 09:15 »
Thanks,
I researched a little bit found out, it is on the Distributor, does not come seperatly, yes new distributo. Picked one off ebay for a fiver, solved the problem.
Now other problems have creeped in, non-stop.
