Author Topic: lamba sensor  (Read 818 times)
Offline IanMK3
lamba sensor
« on: 07 June 2009, 11:28 »
hi im needing a new lamba sensor for my 1994 golf mk3 gti 16v and iv done a search and found 2 sensors for it but im not sure which i need, can anybody help?
http://www.cats2go.co.uk/Default.aspx?PageID=15&CartID=1
Offline funkyfive
Re: lamba sensor
« Reply #1 on: 07 June 2009, 18:12 »
I would look at euro car parts or use this bloke on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400031887036 he was the cheapest and the part was orginal.
Re: lamba sensor
« Reply #2 on: 08 June 2009, 08:25 »
there are early/late type ones. The way to tell is to check the plug, if it is rectangular its early, if it has rounded ends its late:
ABF +Cat 08.92-12.94 Front 4 1000mm - 0 258 003 303 - VAG 021 906 265 C
ABF +Cat 01.95-12.97 Front 4 690mm  - 0 258 003 584 - VAG 037 906 265 S
Not that it really matters, you can get a universal sensor. With these you chop the old plug off and splice it to the new sensor using the supplied connector block.  The one you need is:
4 wire - 0258986506 (LS06)
Four wire sensor with 12 watt heater and grounded case
Offline grimmer
  • www.check-light-on.co.uk
Re: lamba sensor
« Reply #3 on: 08 June 2009, 19:33 »
yeah as above one with plug on is stupid money for 16v
just buy a 4 wire zircona universal and put plug on to it, done mine last week works a treat and only 22 quid.
MK3 GOLF GTI 8V  now converted to 16v!!
Offline Len
Re: lamba sensor
« Reply #4 on: 08 June 2009, 20:54 »
Got mine from GSF
www.sas.org.uk
www.the-ace.org.uk
