Author Topic: Help please.  (Read 1477 times)
Offline manny2k80uk
Help please.
« on: 06 June 2009, 20:18 »
Ive just had my 1.8t agu r-tech remaped and i want to know wats next for my tuning. Intercooler? Decat induction kit. And wil i neet it retuned
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Help please.
« Reply #1 on: 06 June 2009, 20:23 »
Smoothed Air Box
Pipercross panel filter
SS Exhuast system with sports CAT (For MOT)
Forge Silicone TIP
Forge Boost Hoses
Good service
K03s turbo
and then take it back n get it remapped.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Help please.
« Reply #2 on: 06 June 2009, 20:24 »
Smoothed Air Box
Forge Silicone TIP
Forge Boost Hoses
Good service
K03s turbo
You can do all of those (bar the KO3-s conversion) w/o the need for another map. ;)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline manny2k80uk
Re: Help please.
« Reply #3 on: 06 June 2009, 20:30 »
Wat will a smothed airbox do 4 it and a forge tip. Wat is dat i allready have the forge 007 dump valve. Also wat about a induction kit and intercooler with the remap in mind
Offline jonnyturbo
Re: Help please.
« Reply #4 on: 06 June 2009, 20:35 »
yep all the above will improve ur map
Re: Help please.
« Reply #5 on: 06 June 2009, 20:39 »
Ind. kits generally suffer from what's known as 'heatsoak'.  They get hotter than the OEM airbox due to the engine bay temps., & as colder air = more power, this is bad.  (On a cold day in winter, though, they MAY be better). ;)  IK's definitely sound better, though.
The OE airbox has plastic 'flaps' left inside it from the moulding process, so cutting these out & then smoothing the inner surface increases the airflow efficiency.
The R32 DSG intake is bigger than the stock item, allowing more air to be drawn into the engine = more power.
TIP = Turbo Inlet Pipe.  These don't bend on heavy load from re-mapped cars like the OEM item does.
« Last Edit: 06 June 2009, 20:41 by Ivor Mk4 Turbo »
Offline jonnyturbo
Re: Help please.
« Reply #6 on: 06 June 2009, 20:43 »
i just got standard airbox and a piper X filter in works a treat
