Author Topic: Engine swop?  (Read 1588 times)
Offline Tramp
Engine swop?
« on: 06 June 2009, 13:54 »
Can i stick a MK2 engine in a MK1?
If so what happens to the ECU....s it just thrown away as surely it's needed for all electrics
Re: Engine swop?
« Reply #1 on: 06 June 2009, 17:27 »
Yes if fitting an 8v then all you do is swap your parts over as required including binning the ecu, if fitting a 16v then you will need the ecu etc.
