Author Topic: 1997 Golf GL... Headlight Question  (Read 2117 times)
Offline interex
« on: 05 June 2009, 21:42 »
Hey guys, I'm new here and did a quick search but not finding exactly what I'm looking for.
I have a 4 door 97 GL with a 2.0L and 5 speed.
I hit a deer a while back and ordered a new fender, hood, and grille with no problems at all.
I ordered a set of headlights and when they arrived they looked identical to my headlights except one thing...  The mounting tabs didn't line up.  I've looked at several different generic headlights on Ebay and all of them have the top mounting tab bent downward, where mine are suppose to be upward.   I don't understand this at all.
How do I get different headlights if none of them look like they will fit?   Everyone says they will fit all 93-98 Golf/GTI but in my case, they don't.
Any insight?
Re: 1997 Golf GL... Headlight Question
« Reply #1 on: 05 June 2009, 21:52 »
They should be bent downward.
Offline Mikester
  • Civic Type R
« Reply #2 on: 05 June 2009, 21:53 »
As far as im aware all golfs, be it gti or not gti, all used the same slam panel, and also the ventos.
I have had brand new, and old, gti and non gti headlights, and never had a problem fitted them. The mounting tabs are just horizontal/downwards and slot into the slam panel.
Have you got pics of what your problem is? As its sounds odd.
Offline interex
« Reply #3 on: 05 June 2009, 21:57 »
Look at this for example...  Look at the passenger side mounting tab, it's not at the right angle to be bolted in, this is what I'm talking about.  I bought a set just like these and they wouldn't even align all the other holes, just the top inner holes.   And the bottom pic is OEM/Fatory, the tab is upward like on my car.
« Last Edit: 05 June 2009, 22:00 by interex »
« Reply #4 on: 05 June 2009, 21:57 »
That is correct.
Offline VR6-Joe
« Reply #5 on: 05 June 2009, 23:51 »
I'm guessing your car is probably L/H/D?
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 06 June 2009, 00:03 »
still the same....
Offline VR6-Joe
« Reply #7 on: 06 June 2009, 02:12 »
still the same....
Hmm that's really odd then
Seems like something you'd find on an import model..
Offline interex
« Reply #8 on: 06 June 2009, 02:56 »
I am American, my wheel is on the standard side for American cars, not sure if import or not does have a difference...
Well, it doesnt make sense.  Whether or not there was any specific model difference, my headlights from my car bolt on just right, the replacements I bought which look exactly the same, do NOT bolt up.
That specific upper far outer side mounting tab is curved downward on the aftermarkets, mostly all of the ones I've seen and my car has that same tab except moved forward a little, and it is curved upward, making it bolt on from the front, not the top like the aftermarket suggests.   The lights absolutely did NOT fit, and I don't know why.   I'm really starting to be annoyed by the entire thing cause I really need to get my car fixed so I can start driving it again.
I just want to know why all the ones I find, even that on ebay... have the mounting tab on top, curved downward, and my car has them upward like the picture I posted above.
« Last Edit: 06 June 2009, 02:58 by interex »
Offline VR6-Joe
« Reply #9 on: 06 June 2009, 12:34 »
Do all the other 3 mounting tabs line up?
If so, just cut that odd one off, the other 3 bolts will keep it secure :grin:
