Author Topic: help with central locking please!!!!!!!!  (Read 2956 times)
Offline _Adam_
« on: 05 June 2009, 20:43 »
latley i noticed the lights didnt flash when locking the car and the red led doesn't flash when locked, and today i realised the drivers door doesnt lock at all, and only locks SOMETIMES with the key, its still very temprememntal. the passenger door has always been a bit tempremental, locking every time but sometimes only opening when the interior unlock button is pressed.
im in need of advice pls!!!
Offline Hurdy
Re: help with central locking please!!!!!!!!
« Reply #1 on: 05 June 2009, 22:55 »
You need someone nearby who can hook you up to VAGCOM/VCDS to find out if your central locking system is working correctly or not. They could alter a few settings from the convenience section to see if it makes any difference.
Maybe a silly question, but I'll have to ask it.....have you tried swapping out the batteries in the key?
Seat Leon Cupra Black 290 DSG
Offline ub7rm
« Reply #2 on: 05 June 2009, 23:27 »
An old mk4 problem was the switches in the door handle would fail so the car wouldn't lock / unlock properly because it didn't really know if the door was open or shut.  Are your courtesy lights OK?  Coming on when you open the door / going off at the right time?  If not it could be the problem.
Best bet as Hurdy says is VCDS.
2020 BMW 128ti
2017 Golf GTD Estate
neo66
« Reply #3 on: 06 June 2009, 10:23 »
Sometimes when I lock mine the indicator lights don't always flash once!.?
Offline kevinz925
« Reply #4 on: 06 June 2009, 11:13 »
I just had this problem once. Later I found It was because I didn't shut my tailgate securely. And I often found the inter locking light on the door lit on constantly instead of flashing. I haven't given it a second thought for it's not causing any problem so far...
Offline _Adam_
« Reply #5 on: 06 June 2009, 12:28 »
no havent tried swapping batteries, always hear a locking / unlocking noise on all other 3 doors when i press the buttons, could it still b a cause? how much will VW charge me to look at it?
Offline _Adam_
« Reply #6 on: 06 June 2009, 12:28 »
and yes interior lights are all fine
Offline _Adam_
« Reply #7 on: 07 June 2009, 12:06 »
im in bridgend south wales, anybody close to me have VAGCOM/VCDS? wat's the going rate? lol
