Author Topic: glove box refit  (Read 973 times)
Offline juleshs
glove box refit
« on: 05 June 2009, 18:24 »
not sure if this is the correct place for this
last week i took out my dash in search  of a leak, while it was out i removed the complete glovebox to make it a little easier to route the wiring when i putit back. well the leak is cured the dash is in the glovebox however is not. would i be right in thinking the dash as to be out to fit the glove box???
Offline Benrevs
Re: glove box refit
« Reply #1 on: 05 June 2009, 18:51 »
I had this problem.. its a hog to fit.  Slacken of the L/H screw in the rain tray that holds the dash on and all the other main ones on the glovebox side. This should give you enough movement to wedge it back in. Just dont forget the light!! Ben
Offline juleshs
Re: glove box refit
« Reply #2 on: 05 June 2009, 18:54 »
cheers pal
Offline Ben Lessani
