Author Topic: Help im stumped!  (Read 7836 times)
Offline Steve_PD
Re: Help im stumped!
« Reply #10 on: 12 June 2009, 20:21 »
Gutted  :cry: sounds like the turbo's gone, dont go to the dealers......£1100 brand new  :lipsrsealed:
I'd try to get a second hand one from a breakers or ebay
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #11 on: 13 June 2009, 21:28 »
 :cry:
If its the Variable vein thingy,   does that mean the turbo will carry on to work as normal (just slower) for a while?   If its going to run ok for now i will wait and see what hybrid goodies my next pay packet might bring... otherwise might just flog it back to the garage.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Rhyso
« Reply #12 on: 14 June 2009, 10:17 »
:cry:
all you're doing is delaying the inevtiable - what its currently doing is destroying the housing and the vanes
i'd get rid back to the garage  :lipsrsealed:
Offline Rmachines
« Reply #13 on: 14 June 2009, 11:01 »
I cant belive i have had a MK4 for 5 months and it already broken!  :grin:
the things only done 90,000 miles,  My mk3 TDI has just ticked over 180k and still on stock turbo   :shocked:
Offline Rmachines
« Reply #14 on: 14 June 2009, 15:31 »
Just before i atack my car...  Could it be the VNT actuator/pipes to it... ?
Ok i have managed to activate the VNT actuator now by sucking on the pipe... it moves but not as smooth as it should do,  So i took some advice and took it out for a real hard ragging!! Its now come to life again... It started pulling really hard so its better but its a bit laggy now, so its not perfect but it pulls hard once i hit 2.5k
I understand the actuator can be changed without a whole new turbo,  should i give that a go first?   I will change all the pipe work too as some of it is damaged, although nothing is leaking as i sucked into them all and no vac was lost.
« Last Edit: 14 June 2009, 16:46 by Rmachines »
