The garage
020 gearbox problems
Topic: 020 gearbox problems (Read 1261 times)
mk2_abf
05 June 2009, 15:28 »
was out today in my mk2 when i started to get crunch in 2nd then suddenly i lost all my gears
which happened right on top of busy round about which i had to push to the next exit to safty i managed to get 2nd back but cant get no others anyone have any ideas cant do nowt till it stops raining
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: 020 gearbox problems
05 June 2009, 16:50 »
have a look at the linkage first of all, then see if you can spot any gear oil leakages
mk2_abf
06 June 2009, 19:39 »
after an hour of setting gears up i finally got to the source of the the problem i found a nut worked its way loose tightened it up and my gears are nice and tight 100% better to drive now
The garage
