Author Topic: getting hot hot hot  (Read 1143 times)
Offline Chrisbrown.92
getting hot hot hot
« on: 05 June 2009, 15:17 »
hi
i bought a mk3 this week and took it out for the first time today . its getting very hot . so i checked the water and it was very very low so i topped it up and its fupll . i checked the oil thats fine but its getting to like 110 -120 degress  :huh: ?? anyone know what it could be , is it me being silly ?
chris
adamrob69
Re: getting hot hot hot
« Reply #1 on: 05 June 2009, 15:36 »
temp should sit in the middle of the gage (90 is it?), howvere not sure on the problem if you have replaced the coolant and checked over the cooling system?
« Reply #2 on: 05 June 2009, 15:43 »
yea i just put some water in no collant would that effect it ? also how do i check the collant system ?
adamrob69
« Reply #3 on: 05 June 2009, 15:59 »
i dont really know much about it to be honest, water should be OK, as long as there was enough coolent in there in the first place! i would just follow the pipes around the engine check ther in working order no splits etc, carnt help much more then that im afraid.
Offline robz
« Reply #4 on: 05 June 2009, 18:28 »
if i were you i would drain your coolant and get some summer mix in - ussualy 50/50 water/coolant.
is your cap sealing pressurising??
is the bottom pipe off the rad warm aswell when its hot??
Offline gazpowells
« Reply #5 on: 05 June 2009, 20:20 »
as above mate  get yourself a new expansion bottle cap and check the bottom rad pipe gets warms. you may need a new thermostst
does your fan kick in ?
Offline boneybradley
  • Back in a Mk3...
« Reply #6 on: 05 June 2009, 20:23 »
the oil temp switches are known to give false readings too.....get the water issues sorted and if its still high then check the switch
VW BUSH
« Reply #7 on: 05 June 2009, 21:24 »
Is the fan/switch ok?
