Author Topic: Brake fluid change + Free visual check.  (Read 1197 times)
Offline Dubbz
« on: 05 June 2009, 14:12 »
 :grin:
My car was booked in today for the brake fluid change (£45.40) I was hoping it would stop the cause of my clonking/clicking/tapping/knocking noise when applying the brakes :undecided: but it has not.  :rolleyes:  :lipsrsealed:
Maybe it's my corroded antiroll bar thats causing the noise?
On VW's visual check three faults.  :rolleyes:
Ribbed belt perished. Not TB.
Antiroll bar corroded.
Undertray damaged.
But this is the best bit of todays visit.  :evil:
If i have the ARB replaced, then i'm going to need an "Optiline"...........lol er what.  :huh:
Yes, its a four wheel alignment, hmmmmmmmmmmm just had that done a couple of weeks ago for £43
I had to ask how much that would cost. Good job i was sitting down!!!!  :shocked: It will take about 2 hours and be £135-ish  :shocked:
Whether she gave me the price for fitting the ARB + the Optiline i'm not sure, or if that price is just for the Optiline.
« Last Edit: 05 June 2009, 16:30 by Dubbz »
2002 TDI se 100bhp-ish Auto/tip Black Magic. :cool:
Offline old_n07
Re: Brake fluid change + Free visual check.
« Reply #1 on: 05 June 2009, 15:10 »
To fit the ARB they will drop the subframe, that's why it would need aligning after, did the £135 cover the new arb, bushes, fitting and alignment? As the ARB is coming up as £80 on ETKA.
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline Dubbz
« Reply #2 on: 05 June 2009, 16:24 »
Neil
Thanks Neil.
I didnt know the subframe had to be dropped.  :undecided:
VW just called me back, to fit the ARB plus bolts, bushes etc with labour, VAT comes to £198.07  :shocked:
The Optiline is £136.85  :laugh:
Offline 20v
« Reply #3 on: 05 June 2009, 19:51 »
dubbz optiline is the same as 4 wheel geometry an it just so happens were i work the have a 4 wheel geometry macheine u can sit wait an watch the computer as its all set up n as far as i can remember theres only 1 adjustment an that will cost u just short of thirty quid exactly the same as a optiline :smiley: LOZ 20v
