Author Topic: Front caliper binding?  (Read 1453 times)
Offline Mr_Orange
« on: 05 June 2009, 13:21 »
What is a binding front caliper going to to to the surrounding area?
Screw up disc and pads obviously, but could it cook the bearing and degrade / burst the cv boot from the excessive heat?
Just considering my current split cv boot and assoc problems from a different angle  :wink:
Build thread clicky
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Front caliper binding?
« Reply #1 on: 05 June 2009, 13:42 »
I don't know, but you could strip the brakes down & grease the slider bolts like I did. :)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Mr_Orange
« Reply #2 on: 05 June 2009, 13:47 »
I hoped it was simply a warped disc, It's got a bit beyond me doing it now:
n/s Disc is well knackered and I'm guessing pads are done in too.
n/s Outer CV is split (grease everywhere).
n/s Lots of noises in motion (chirping and vibration) and under braking (judder).  Bearing/CV joint/disc?
Could an ABS fault be playing a part in this series of issues?   :undecided:
Build thread clicky
Offline james2
  • No scammers please.
« Reply #3 on: 05 June 2009, 13:59 »
it sounds like a nightmare :grin:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline alex160
« Reply #4 on: 05 June 2009, 17:37 »
it isnt the sort of thing to leave and see what happens, if your not sure what the problem is then take it to your local garge and get them to investigate and sort it mate, you dont want to be driving round with a car which has a fooked disc and pad set one side, it could result in all sorts of bad things.
2001 Golf GT TDi  150bhp/ 250 ftIb torque  *No smoke, No poke*
Jamex coilovers, 8k HID's, 18" RS6 alloys, Pipercross panel filter. Stage 1 Revo remap.THS FR3 engine mounts, Anniversary headlamps. GTI rear spoiler, Miltek largebore decat/downpipe, Pro-speed cat back exhaust system (V6 4mo style tailpipes) *SOLD*
2002 Golf GT TDi 130. Allard egr removal kit, 18" Audi rs6 alloy wheels. Mk5 rear aero wiper.gen R32 roof spoiler, JOM coilovers, JOM heavy duty adj droplinks
Offline Mr_Orange
« Reply #5 on: 05 June 2009, 18:56 »
You are correct and I appreciate what you are saying, but I don't deserve a telling off!   :angry:
I was planning doing the disc/discs this weekend, but the boot intervened with those plans and I only found that last night when I got in.  It has been in the garage today, I was simply on here looking for some ideas what to expect if they were to sort it out.  Not hoping that by asking you it would magically repair itself!
CV had split, contaminated brakes, which started rubbing, which developed heat, which knackered the rotor.
So: CV boot replaced (CV itself is still OK) & both discs replaced as they were getting thin.
Took it out to bed the new rotors in properly and the problem is now sorted.
The end.
Build thread clicky
« Reply #6 on: 05 June 2009, 19:22 »
:huh:  Telling off?!  :undecided:
Just looked like some sound advice from where I'm sitting!
Offline alex160
« Reply #7 on: 05 June 2009, 20:10 »
was telling you off, was just giving advice to get it sorted asap really as its abit of a safety issue for yourself and other road users.  :lipsrsealed:
