Author Topic: ABS Query  (Read 1171 times)
adamrob69
ABS Query
« on: 05 June 2009, 13:06 »
I'm a bit bemused with my ABS light atm. It doesnt come on when you turn the egnition, but the airbag light does. All the fuses are present and good. I vag comd it, it seen the abs controller and reported no errors. took the panel off the warning lights and there were not cut wires, and for some reason i carnt get in to replace the bulb (or check it?). Any ideas?
Offline VR6-Joe
Re: ABS Query
« Reply #1 on: 05 June 2009, 13:14 »
Are you referring to your 1.4 Golf? If so, it shouldn't have ABS :undecided:
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
adamrob69
Re: ABS Query
« Reply #2 on: 05 June 2009, 13:15 »
nooo, i just baught an 8v CC!
Offline VR6-Joe
Re: ABS Query
« Reply #3 on: 05 June 2009, 13:16 »
Oh fair enough, lol
People often take off the front cover of the ABS/airbag light panel and put a piece of black tape over where the ABS light shines through?
If not, it could be the bulb, try getting another ABS/airbag light panel from a scrappy?
adamrob69
Re: ABS Query
« Reply #4 on: 05 June 2009, 13:19 »
yes thats my next step, can you not take apart the plastic housing behind the panel then? i would be surprised if you couldnt change the bulb!?
Offline VR6-Joe
Re: ABS Query
« Reply #5 on: 05 June 2009, 13:27 »
You probably could change the bulb if you're an expert with a soldering iron lol.. I took mine apart and found that the bulbs are all soldered in so I just got another panel from the scrappy instead.. I guess if they're soldered in, then people can't remove them when they're permanently on due to a fault..
adamrob69
Re: ABS Query
« Reply #6 on: 05 June 2009, 13:29 »
yes you are probably right there becuase its a safety feature it needs to be a sealed unit? im guesing they are LED's and not bulbs then! Trip to the scrapy i think
