Author Topic: 2nd Gear crunch - knackered synchro??  (Read 4045 times)
Offline [steve]
  • Getting Stuck In...
« on: 05 June 2009, 10:21 »
My Golf seems to crunch when changing to 2nd too quickly, if you give it a second or two after dropping out of 1st before putting it in 2nd, it is fine...
Is it just the synchro mesh and is it a big job to fix. Also, does it have any long term impact on anything (gearbox etc).
Cheers.
Steve.
Offline Horney
Re: 2nd Gear crunch - knackered synchro??
« Reply #1 on: 05 June 2009, 10:29 »
THis is very common on MKII's. It's a sign the syncro on 2nd is badly worn. Does it get better once the gearbox has warmed up?
Try changing the gearbox oil (Search on here for the best tuse as I can't remember off hand) as this often improves it immensley.
Nick
VeeDubGTI16v
« Reply #2 on: 05 June 2009, 10:32 »
if the bushes are worn this will make things worse as well
unless you want to shell out £500 for a box refurb id get used to it!
i think its redline mtx? your on about nick
Offline Horney
« Reply #3 on: 05 June 2009, 10:37 »
That's the stuff mate, cheers :-)
Thought you were at the track day today?
nick
VeeDubGTI16v
« Reply #4 on: 05 June 2009, 10:43 »
just about to leave!
Offline Horney
« Reply #5 on: 05 June 2009, 10:46 »
Ah cool, have a good one!
nick
Offline [steve]
« Reply #6 on: 05 June 2009, 12:00 »
Cheers guys, will check the gear oil tonight.
It does seem better when the box is warm... its only a little crunch at the mo too, so not too bad  :wink:
Offline Gloves88
« Reply #7 on: 05 June 2009, 13:31 »
Your other option is to double cluch until it warms up...:)
Offline wil0
« Reply #8 on: 05 June 2009, 15:01 »
change to redline mtx, and do the gear linkage bushes. mine had quite a bad crunch, and now theres nearly no crunch atall.
3Door Oak Green 91 MK2 16v GTi
