Author Topic: how does the dipstick tube come out  (Read 1712 times)
Offline 20v
« on: 05 June 2009, 08:22 »
as mine just broke in half as i was takin my dipstick out just clean snapped an does ny one no the part number please need to sort this asap thanks in advance
Offline barry-gti
Re: how does the dipstick tube come out
« Reply #1 on: 05 June 2009, 08:28 »
the're on ebay for like £3.
you need to take the lower engine cover off. unscrew the plate underneath that. the plate is holding it in so once thats off you can just slide the top part from there and then try and get the bottom part off. i'm at work so i havn't got pics but thats basically what you have to do lol
Offline Waffs1984
  • Spacers are for chumps...
« Reply #2 on: 05 June 2009, 08:30 »
Sorry i can't help you with the part number but this is a fairly common occurence, have a search and i'm sure you will find it  :wink:
As far as i am aware you have to undo the plate on the front of your inlet manifold (2 x 5mm allen bolts?) and then it should just pull upwards and out? Note that there is a locating tab on the tube that fits in a slot on the plate, remember to slide it in before you bolt the plate back on!  :smiley:
Oh yes, and as Barry GTi said, you need to remove the lower engine cover first!
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline 20v
« Reply #3 on: 05 June 2009, 08:39 »
ill give it  a go
cheers lads
Offline Voodoo-Music
« Reply #4 on: 05 June 2009, 14:58 »
Mine was a nightmare to get off. Ended up snapping it of and using a flat driver and a hammer to split it down the side
Not advised doing it this way though lol
Offline barry-gti
« Reply #5 on: 05 June 2009, 15:35 »
it was b*ll*cks....but not that b*ll*ocks lol
Offline golfgar
  • Audi A6 estate/subaru wagon
« Reply #6 on: 05 June 2009, 17:11 »
euro car parts stock the dipstick guide,£2.76 inc vat,think there £4 ish from the stealers,watch out when removin the old broken one!! i had some bits drop into the sump :angry:flush, new filter,oil and another £50.00 gone
Offline 20v
« Reply #7 on: 05 June 2009, 19:46 »
£7.88 + vat my vw seem to be robbing bstards all the prices peeps put up mine is like 3 4 quid more lol
