Author Topic: ARB knocking on wishbone  (Read 1225 times)
Offline james_16v
  • 1986 Golf GTI 16v
« on: 04 June 2009, 14:55 »
Changed the nearside wishbone this morning to try and sort the knock that I had when pulling off.
All went great with fitting but I still get the exact same knock when accelerating.
Upon further inspection I found the ARB is almost touching the wishbone on the nearside but has a gap that I can fit my fingers between on the offside.
Im guessing its this hitting that is causing the knock.
How can I sort this, is it just a case of re centering the ARB? how do I do this?
Any help is greatly received I feel like I've wasted the morning.
Re: ARB knocking on wishbone
« Reply #1 on: 04 June 2009, 15:18 »
follow the wishbone back to where it goes thru a rubber bush on the subframe, there is a 13mm clamp bolt here.  loosen this (dont undo it fully!!) then give arb a good yank to shift it along, this wont be easy!  bit of spray lube might help.  this is assuming its just been fitted wrong, and not that somerthing is bent underneath!
Offline james_16v
  • 1986 Golf GTI 16v
« Reply #2 on: 04 June 2009, 16:24 »
Cheers, Ill give that a try tomorrow.
Its came on all of a sudden and I have definitely not bumped it to cause anything to bend so im a bit miffed as to why its started.
Offline james_16v
  • 1986 Golf GTI 16v
« Reply #3 on: 05 June 2009, 15:34 »
By the way I am also a really big GAY with a really big willy!! not sure if this is related but i have to get it off my chest:lipsrsealed:
