Golf mk3
hardmonkeys
Bias Pedal Box
Topic: Bias Pedal Box (Read 825 times)
Edwin
Bias Pedal Box
04 June 2009, 13:15 »
Any ideas where I can get one from?
Diamond Hell
Serious forum addict
Opinions я Us
Re: Bias Pedal Box
04 June 2009, 13:25 »
You realise the extent of the changes you're going to need to make to the whole braking system to install that, right?
Edwin
Re: Bias Pedal Box
04 June 2009, 14:16 »
Yup, I'm quite familiar with turning road cars into rallycars
My only other option is to remove the current brake system (ABS pump etc) and replacing it with a non ABS master cylinder etc from a standard car
Diamond Hell
Opinions я Us
Re: Bias Pedal Box
04 June 2009, 23:47 »
Sorry - very basic initial post meant you could have been a numpty, who once heard a pedal bias box is cool, or something.
This might fit, although you need to check the bolt pattern on the servo - check yours and I'll check mine (Golf2) tomorrow and it should be obvious whether it'll even bolt in...
http://cgi.ebay.co.uk/BALANCE-BAR-BRAKE-BIAS-PEDAL-BOX-FOR-VW-GOLF-MK2-RALLY-_W0QQitemZ320310297217QQcmdZViewItem
Last Edit: 04 June 2009, 23:51 by Diamond Hell
Edwin
Re: Bias Pedal Box
05 June 2009, 09:42 »
Thanks, I'll have a look over the weekend and report back. Is yours servo assisted or have you built up a decent set of leg muscles to use it?
Golf mk3
hardmonkeys
Bias Pedal Box
