Poll
help
help
3 (75%)
help
1 (25%)
Total Members Voted: 3
Author Topic: rear fog light problem  (Read 1714 times)
Offline dazmk2dub
« on: 03 June 2009, 22:41 »
well ma mk2 failed m.o.t today on the flippin rear fog light everything else was mint tryed everything i can changed bulb, checked wires fuses etc still nothing any help please as retest is this saturday thanks
Offline juleshs
Re: rear fog light problem
« Reply #1 on: 03 June 2009, 22:58 »
try the switch
« Reply #2 on: 04 June 2009, 08:50 »
Have you checked for power at the bulb.
Offline dazmk2dub
« Reply #3 on: 04 June 2009, 11:12 »
if you mean fog switch everythin seems alrite there light comes on switch, ill check power with a power probe later thanks  :smiley:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #4 on: 04 June 2009, 21:09 »
Without teaching you how to suck eggs, you have tested it with the headlamps on havn't you, after replacing the bulb?
« Reply #5 on: 05 June 2009, 12:32 »
where is your hazard switch, dash or column?
Offline DarnPB
« Reply #6 on: 05 June 2009, 12:36 »
I voted HELP! :cool:
Offline Gloves88
« Reply #7 on: 05 June 2009, 13:46 »
Me too! :D
I would get the voltmeter out and starting at the bulb work back to see where you're loosing power.
My bet is it’s either the wiring or the switch. I seem to find 9/10 electrical probs on a mk2 are wiring related (I guess it is 20 odd years old now), next things to go are usually the switches
Offline AdamMk2
  • Beautiful
« Reply #8 on: 05 June 2009, 16:52 »
This may sound ridiculous but I thought mk2's have a lamp holder position for the fog in both sides However one is unused, usually blanked by the light backing, which I may add is removeable.
Your not by any chance trying the wrong side upon which someone has removed the blanking bit in the past are you and it happens to be the other side!?
 :cool:
Ad
Offline nealey
« Reply #9 on: 05 June 2009, 22:27 »
Mine had this problem last year, i went outside, stuck a bulb in and it still didnt work, i wiggled the bulb about in the holder it came on and has been fine for over a year
