Author Topic: Its too dam hot, air conditioning?  (Read 1579 times)
Offline smoove
« on: 03 June 2009, 16:33 »
Got a mk3 1997 16v GTI, with this dam weather, when i turn the heaters to cold, its not cool enough, warmer than the air outside! Is it possible to put air con in it somehow?
Re: Its too dam hot, air conditioning?
« Reply #1 on: 03 June 2009, 16:36 »
Not really, you would need to find a donor car and transfer all the parts over, would be a lot of work.
Offline Pete Taylor
« Reply #2 on: 03 June 2009, 17:58 »
MAHOOSIVE job that involves chopping up the bulkhead too and replacing the whole front end panel for the twin fan and rad combo. A VR6 setup wouldn't fit either so you'll be pretty hard pushed to find a full setup from a mk3 16v with air con!
Offline oliver07
  • golf gti T 200BHP
« Reply #3 on: 03 June 2009, 18:44 »
selling my vr6 and yes its got air con :wink:
Offline Mikester
  • Civic Type R
« Reply #4 on: 03 June 2009, 19:48 »
Wouldnt bother with this conversion. Its more involved than swapping an engine tbh.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #5 on: 03 June 2009, 22:27 »
air con is a massive job,  I will take on an engine change any day but air con ...thats one thing i would be scared of doing.  :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Khare
  • The bear that khares
« Reply #6 on: 03 June 2009, 22:34 »
as above. Just make do with the standard system blowing hot air to your face  :grin:
Offline PeanutButterPiece
« Reply #7 on: 03 June 2009, 22:46 »
Open the windows.
Offline 6sr
« Reply #8 on: 04 June 2009, 10:01 »
You'd be cheaper to just buy another one thats got air conditioning as standard.
Offline DigiDub
  • If in doubt get a bigger hammer
« Reply #9 on: 04 June 2009, 11:57 »
Plonk in a sun roof to let that hot air out the top  :smiley:
plus
Open the windows.
 :grin:
