Golf mk3
hardmonkeys
car boiling over
Topic: car boiling over (Read 1352 times)
karl29
car boiling over
03 June 2009, 15:29 »
hi can anyone help me ive just changed the water pump and now the fan wont kick in and its boiling over any help would be much appreciated thanks
Andy-H
Re: car boiling over
03 June 2009, 15:38 »
Have you checked the thermostat
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
M616VMA
used to be a golf until i had an accident........
03 June 2009, 15:44 »
sounds like its air locked to me mate....
however worst case is that if you have been running round with a knackered pump on for a while it could have done the head gasket .and now the new pump is fine the preasure thats caused is finding the next weakest point in the system e.g the head gasket.
try filling it up with water and squeezing the pipes to radiator with the coolant res lid off and let it run to temperature see if this cures the air lock problem.
hope this helps.
karl29
03 June 2009, 19:55 »
will try that and thanks for the help will let you know how it goes thanks again
M616VMA
03 June 2009, 20:50 »
also check the big plug on back fan ? fuses for fan might be something as simple as that...
karl29
04 June 2009, 10:33 »
ive checked everything and it seems to be the fan switch in the radiator as theres no white stuff in the dipstick to suggest blown head gasket well hopefully its that also would the thermostat cause the car to heat up quick if its knackered sorry to be a pain in asking you all but i aint got aclue with vws and everytime i have a problem you guys come to my rescue
thanks all
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Reply #6 on:
04 June 2009, 11:52 »
have a read of the coolant faq, covers how to test the stat, fan, switch and also how to bleed the system
christomk3gti
Reply #7 on:
04 June 2009, 15:10 »
blown fuse cause one of my previous car rad fan to stop working.. wont tell u what car it was tho lol :-) I'm embarresed lol
Black 8v GTI............. Whats a Waffle Valve?
karl29
Reply #8 on:
04 June 2009, 22:58 »
thanks tried the fuse its ok lol it must be bad if youre embarresed lol
Golf mk3
hardmonkeys
car boiling over
