Author Topic: Tapping noise that isnt tappets?  (Read 2008 times)
Offline Tubb
« on: 02 June 2009, 23:10 »
got a tapping noise coming from my engine,
it sounds abit like tappets but only happens when the engine is under load, the engine is fine when idleing.
ive replaced the tappets and cam chain but its still the same.
anybody have any ideas of what else it could be?
1987 Golf GTI 16v 2.0 - 1993 Autocavan Demo Car - For Sale!
1992 Pulsar GTi-R
Offline danny_p
Re: Tapping noise that isnt tappets?
« Reply #1 on: 02 June 2009, 23:19 »
bottom end,  big ends ?
all the VW's have gone bar 1.
Offline mr self destruct
« Reply #2 on: 02 June 2009, 23:22 »
Pinking? Is your timing ok?
A-reg mk2 gti, first registered 01-05-84.
Know of any earlier mk2s?
Offline Tubb
« Reply #3 on: 02 June 2009, 23:26 »
i re-did the timing last weekend so its not that.
how can i check the big ends/pinking?
1992 Pulsar GTi-R
« Reply #4 on: 02 June 2009, 23:34 »
If your timing's ok the engine won't be pinking.  :smiley:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 02 June 2009, 23:37 »
You can sometimes get a tapping noise from a blown exhaust gasket, particularly if its blowing where the manifold is bolted to the head...
Tom
Offline Tubb
« Reply #6 on: 02 June 2009, 23:41 »
hmmm, il have a look tomomrow, cheers
1992 Pulsar GTi-R
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #7 on: 03 June 2009, 12:53 »
Not exactly. Depends on how the mixture is set up. If it's running too lean, then pinking is possible. Also if you have a hotspot within the cylinder or the wrong heat range spark plugs, you may also get pinking. :wink:
« Reply #8 on: 03 June 2009, 13:43 »
Piston slap maybe.
Offline Tubb
« Reply #9 on: 03 June 2009, 18:59 »
its not the exhaust blowing as ive just checked that
i think the bottom end's on the way out as its just developed a new knocking noise  :sad:
1992 Pulsar GTi-R
