Author Topic: stange one.....  (Read 4616 times)
Offline player.777
stange one.....
« on: 02 June 2009, 17:44 »
recently had 4 new tyes fitted, and for some reason this started as soon as they were on, but can't see how they are related at all!!  the problem is that the boost from the turbo used to kick in at 2000rpm, if the revs were lower than this, i'd change down to stop the car shaking like a jackhammer on acceleration- but now in fourth, the boost comes in a lot later, maybe 3000 or more, and also there doesn't seem to be the power that there once was.  anyone anything simliar?? or am i just imagining it??
Offline richw911
Re: stange one.....
« Reply #1 on: 02 June 2009, 17:46 »
Faulty N75 valve?  :undecided:
Offline player.777
Re: stange one.....
« Reply #2 on: 02 June 2009, 17:51 »
Ok, searched and see that Dave_R and also 20vTurbo have asked, with no replies- so what is the n75 valve? what does it do, and would i be able to tell if I take the thing out if it's knackered??
Offline richw911
Re: stange one.....
« Reply #3 on: 02 June 2009, 17:55 »
It controls your boost 2 min job to change - try a vag com scan first  :wink:
http://www.peterbeers.net/vw_roadtrip/GTI/GTI_Mods/N75J/N75J.htm
« Last Edit: 02 June 2009, 17:58 by richw911 »
Offline player.777
Re: stange one.....
« Reply #4 on: 02 June 2009, 18:09 »
nice one thanks mate- any of the hertford/ stevenage boys got vagcom??
Offline Steve_PD
Re: stange one.....
« Reply #5 on: 02 June 2009, 18:10 »
Boost control valve = 1KO 906 627 A  :wink: about £34
Could also be a leaking boost pipe  :undecided:
Offline richw911
Re: stange one.....
« Reply #6 on: 02 June 2009, 18:10 »
Are you going to bristol at the weekend few people will have vag com there  :smiley:
Offline Steve_PD
Re: stange one.....
« Reply #7 on: 02 June 2009, 18:13 »
They wont if they get wet  :lipsrsealed: :sad:
Offline richw911
Re: stange one.....
« Reply #8 on: 02 June 2009, 18:14 »
nooo dam it  :angry: :angry:
Offline JC
  • Back in the North.
Re: stange one.....
« Reply #9 on: 02 June 2009, 18:15 »
tis ok water, knew you elitests would moan  :lipsrsealed: :kiss:
