Author Topic: vag alarm  (Read 2808 times)
Offline theclash
vag alarm
« on: 02 June 2009, 16:55 »
noticed under the bonnet on the inner wing l/h side an alarm box. no name on it but on the back it as 998 vag 138. does anyone know if this was standard vag equipment ie factory installed. i have no remotes for an alarm only an immoboliser fob although there is motion sensors each side of the window pillars.
 its a very late 92 8valve
Offline jv
  • Administrator
Re: vag alarm
« Reply #1 on: 02 June 2009, 17:02 »
There was no 'factory' system back then, possible dealer fit item I guess. Seeing as it is ancient and you have no remotes for it, sounds like it is time for it to be ditched or replaced! :)
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline theclash
Re: vag alarm
« Reply #2 on: 02 June 2009, 17:06 »
guess your right, i had ideas of just getting hold of some remotes for it and seeing if it worked but i cant even id the make  :undecided:
Offline nealey
Re: vag alarm
« Reply #3 on: 03 June 2009, 21:21 »
Ive got the same system in mine, you cannot get remotes etc from the dealers anymore and even if you could trying to get someone to code them would be a nightmare
Im going to remove mine at some point and get a new alarm fitted as i only have one remote left and its a bit tempremental
Mine is also a late 92 8v
« Last Edit: 03 June 2009, 21:59 by nealey »
Offline Bcarm
Re: vag alarm
« Reply #4 on: 03 June 2009, 21:27 »
My 92 8v had the very same alarm fitted with the mentioned motion sensors, the remotes opeated the alarm and the remote central locking.
Offline theclash
Re: vag alarm
« Reply #5 on: 03 June 2009, 22:00 »
 guys guys you give me hope  :laugh:
 it must have been a vag extra at the time ive since found out that it is probably a scorpion alarm as used by vag and ive contacted the scorpion dealers (via email) to see if you can still get remotes for it so il keep you posted.
 do either of your alarm boxes have any names numbers on them
 also is the immoboliser at the side of the ignition barrel seperate from the alarm and is that vag fitted
Re: vag alarm
« Reply #6 on: 04 June 2009, 08:52 »
To be honest, with the costs of new remotes and trying to get them to work you might be better to remove it and fit a new more modern system.
Offline nealey
Re: vag alarm
« Reply #7 on: 04 June 2009, 19:41 »
There is a Ci on the remote, the main box for it is behind my centre console so will have to have a look on that at some point and get some numbers off it
Offline theclash
Re: vag alarm
« Reply #8 on: 05 June 2009, 22:30 »
just a quick update as promised....spoke to guy today at scorpion alarms he told me remotes are now obsolete  :sad: and to remove alarm as  in his words `will certainly cause problems`. ho well back to the drawing board for me but if youve got one of these alarms look after your remote
Re: vag alarm
« Reply #9 on: 05 June 2009, 23:54 »
Why would it cause problems, a decent auto electrical specialist will be able to remove it with no issues.
