Author Topic: golf 2.0 gti problems  (Read 1731 times)
Offline Chief ka kar
« on: 02 June 2009, 13:34 »
Can anyone help me. Am having idle problems with my 2.0 8v golf gti 1997 it starts ok and idles fine but if i set off then come to a stop the car just cuts out, but i have noticed if i drop the revs down slowly before coming to a stop its fine but if the revs drop quickly then the car cuts out.
I have just serviced the car myself spark plugs,ht leads, rotor arm dizzy cap, new coil pack etc. Just to see if this helps but no joy. So if anyone can direct me in the right place i would be most grateful
« Last Edit: 02 June 2009, 14:43 by Chief ka kar »
Forget the rest and  drive the best, VR6
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
Re: golf 2.0 gti problems
« Reply #1 on: 02 June 2009, 13:52 »
same happened to me
got new plugs, no change:)
but when i got a new set of HT LEADS, i found one was corroded and not connecting properly:)
soon as i fitted them i never had the problem since
there not to expensive either, mine where £40ish
hope this helps
« Reply #2 on: 02 June 2009, 14:45 »
Changed them as well mate, Think am going to try and clean the throttle body later. I just wanted to know if anyone else had some input on this.
Offline shepgti
« Reply #3 on: 02 June 2009, 14:50 »
Offline denny
« Reply #4 on: 26 August 2009, 13:14 »
hi mate just read about your problem and i had the same one try and jive your throttle body a good clean very easy to do it sorted it for me     :smiley:
Offline wee-golfer
« Reply #5 on: 26 August 2009, 13:44 »
i mate its defo dirty thottle body. had same prob which is now sorted. all u need to do is spray carb cleaner into the thottle body. i put a breather filter on the breather hose end (as this is where the leak was coming from) and one in the rocker cover and it runs fine now, massive improvement
gtigolfthree
« Reply #6 on: 26 August 2009, 14:30 »
+1 check your breathers are not blocked.
Offline Sasase
golf 2 0 gti problems
« Reply #7 on: 27 August 2009, 21:21 »
Hi Guys,
Just bought a 89 16V Golf GTi.
Does anyone know of any good wreckers/shops to get new or used parts in Melbourne?
Offline l333
  • mk2 8v....mk3 8v....mk3 16v.... who says im greedy
« Reply #8 on: 27 August 2009, 22:50 »
89....... try mk2 section mate :grin:
gtigolfthree
Re: golf 2 0 gti problems
« Reply #9 on: 28 August 2009, 10:43 »
Hi Guys,
I wish  :grin: :smiley: :grin:
