Author Topic: wobblng steering wheel  (Read 2237 times)
Offline faz186
« on: 02 June 2009, 11:41 »
guys driving my vr past few days and iv noticed that my sterring wheel wobbles side to side on straight streches, can some1 tell me what is the prob,
is it my anti roll bar links and the arm they are attached to coz im going to change the arm next week
thanks
faz
Re: wobblng steering wheel
« Reply #1 on: 02 June 2009, 11:45 »
Could be camber and tracking.
Offline vdubnut
« Reply #2 on: 02 June 2009, 12:34 »
mine was a pain when i lost a wheel weight!
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
« Reply #3 on: 02 June 2009, 13:14 »
more than likely to be tracking
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 02 June 2009, 18:40 »
tracking doesnt usually cause wobbling that much, causes it to pull a lot though!  I would say you need your wheel balence checked!  might have a buckled alloy?  I had a bad buckle but with loads of weights it got better.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline VW Mel
« Reply #5 on: 02 June 2009, 19:00 »
I have this on my polo, going to get my wheels balenced i think!
If you car is pulling to one side when the steering wheel is straight then that would mostly be the tracking.
Offline faz186
« Reply #6 on: 03 June 2009, 08:43 »
its not pulling to anyside it just wobbles very excessivly i might have it balanced again just to be sure
faz
Offline Edwin
« Reply #7 on: 03 June 2009, 09:24 »
Check your track rod ends and steering arms are ok
Offline MrBounce
  • Bora TDi 130 Highline - usually filthy.
« Reply #8 on: 03 June 2009, 17:05 »
My money's on the wheels being out of balance  :smiley:
Keeping schtum. Mostly.
Offline Khare
  • The bear that khares
« Reply #9 on: 03 June 2009, 17:14 »
+1, mine did this, got 4 new tyres and all the balancing done and it was perfect. Any speed and no wobble now.
