Author Topic: Question on tyre pressure  (Read 14259 times)
Offline kevinz925
« on: 01 June 2009, 13:49 »
Hey I have a rookie question about tyre pressure.
I got my mk5 GTI ed30 in Oct last year. When I picked it up from the dealer, I found the tyres pressure a little bit lower than recommanded on the log book using my own pressure gauge. I drove it to National Tyre and got confirmtion on my suspection. And I told the staff to over-inflate the tyres a little above standard to get a more sporty ride. After that I found my MPG was improving and the cornering was neater. I was quite happy about it although that compromised the ride comfort a little.
I drove the car to the dealer for service last month and later found they lowerd pressure again. I look it up on the net and someone seems to be promoting a 10%-minus principle, which means you will make the best of the performance of your tyre when the pressure is 10% less than the maximum pressure it could afford. On that basis, I will have to pop my tyre up to 47 psi and the recommendation on the log book is 36psi, which is a huge different.
Which should I stick to?
Offline ifti
Re: Question on tyre pressure
« Reply #1 on: 01 June 2009, 14:57 »
I usually stick to around 39psi.
neo66
« Reply #2 on: 01 June 2009, 14:59 »
47 psi is way too much!!, also when the air in the tyre warms up it will expand.
You won't be wanting a blow out! I think 36psi is still a little excessive too!
Have a look on your tyres- it will say 50psi max and some say 'do not inflate above 40psi' they have multiple warnings on these factors.
I can understand over inflating them will give a bit more MPG but i would take safety over MPG anyday! I keep mine to about 33psi.
« Last Edit: 01 June 2009, 15:14 by WILLZIE »
Offline Hurdy
« Reply #3 on: 01 June 2009, 15:55 »
I've always used 36psi for the road and then for QTR mile runs, dropped the front pressure slightly.
I'm on 19" though and so needs a slightly higher psi imho. :smiley:
Seat Leon Cupra Black 290 DSG
Offline kevinz925
« Reply #4 on: 01 June 2009, 16:02 »
But 36psi is recommended on the VW log book. And it suggests you should inflate them further if you car is going to carry heavy load - I really have no time to spend on adjusting my tyre pressure everyday according to the temperature and loads. But I know it is a crucial factor for performance, economic and safefy. It really gives me a headache !
Offline bacillus
« Reply #5 on: 01 June 2009, 16:26 »
Actually 2.4 bar is more like 35psi...   :smug:
Without traction power is nothing!
Offline stealthwolf
« Reply #6 on: 01 June 2009, 16:42 »
But it's 2.6 bar which is 37psi, which is what I use.
In my previous car, it had the recommended settings for less than half-load and for more than half-load for tyre pressures. I'd only adjust if I knew I was carrying a lot (eg moving from place to place).
Offline mafri
« Reply #7 on: 01 June 2009, 17:28 »
My fuel cap definitely says 2.4 bar.....
Diamond Black Golf GTI, DSG, Monza IIs, Cruise, MFSW, Rear Tints and Ipod. VRmmmmmmmm!
Offline stealthwolf
« Reply #8 on: 01 June 2009, 17:44 »
Maybe it's because mine's an ED30? Has 18" rims rather than 17s that are standard with the GTI.
Offline ifti
« Reply #9 on: 01 June 2009, 18:45 »
Yup, my fuel cap says 2.6 bar.
